Motion Sensor Wiring
Posted: Tue May 02, 2017 2:38 am
by lydell.aaron
Hello. I am working on behalf of the Lumafi Arts (California) team in San Diego. Can someone please explain to me the correct wiring for the motion sensor? On the site, I believe this is called the "Occupancy Switch - In Ceiling."
http://orders.lumencache.com/product-p/p-mot-irtc-a.htm
This switch appears to be an open-collector style of design, so it appears to require current-limiting resistors to limit the amount of current required/consumed (sunk) by the switch. We are able to dig for more information but want to ensure we are wiring things correctly.
I appreciate your guidance in advance,
Lydell Aaron
Re: Motion Sensor Wiring
Posted: Fri Aug 07, 2020 10:48 pm
On the Cat5 that has the L2-SW or L2-DM or L2-WP module (the input/control module) in the PDM, connect the motion sensor to a SIB accessory harness. They have 4 wires coming out:
Black (G) Connect to Occupancy sensor GND or Vin-
Red (12V+) Connect to Occupancy sensor 12Vin+
Green (C) don't need to connect (this is the "Common" wire)
White (S) Connect to the Occupancy sensor "B" output through a 7500-ohm resistor. (This is the "Switch" wire)
You can add momentary switches to the same Cat5 like the L3-WK-D decora switch. This allows manual control of the light as well as setting the dim/restore level the occupancy sensor will trigger. You can also add a light on the same wire, just put the appropriate driver on top of the L2-DM module at the PDM.
If you have TWO motion sensors, there's an adapter to do that to make wiring the 7500-ohm resistor a snap. Just plug the adapter in as per the drawing <will add link later when new website is up>.
dapoxetine maximum dose
Posted: Fri Nov 08, 2024 2:58 am
Some anti epilepsy drugs make birth control pills or oral contraceptives OCPs less effective <a href=https://fastpriligy.top/>priligy generika dapoxetine 60mg</a>
dapoxetine vs tadalafil
Posted: Sun Nov 17, 2024 10:40 pm
Mellon, S, et al priligy amazon canada Tamoxifen correctly switched ОІ gal to GFP in CMs Figures 2A 2C
