USB Outlet Wiring
Posted: Thu Oct 05, 2017 3:49 am
USB and USB-C (USB-PD) appears to be on a trajectory to become the de facto standard for powering modern devices.
LumenCache is sometimes described as "Built-in USB for Homes and Offices". A plug-in AC powered USB adapter is limited to only providing power, but USB is a well-defined communication bus so a majority of it's benefits are lost. LumenCache allows your USB powered devices to digitally connect to your home gateway just like it was connected to a USB port on your computer.
To provide these capabilities, wire to USB jacks as follows:
For USB 1A and 2.1A only, a single Cat5 at 12V PDM input is ok.
For 2.4A it is recommended to use Cat6 with 24V PDM supply.
USB-C/USB-PD can provide up to 100W so we recommend using LC-Bus daisy-chaining up to 8 outlet locations from the same panel homerun.
See wiring guide from the Resources Tab on the LumenCache website: http://lumencache.lighting/wp-content/u ... Wiring.pdf
USB home gateway?
Posted: Fri Oct 06, 2017 10:14 pm
by George Webb
dc wrote:LumenCache allows your USB powered devices to digitally connect to your home gateway just like it was connected to a USB port on your computer.
What is "home gateway"? Examples?
Thank you.
Best regards, George.
kamagra dapoxetine
Posted: Mon Nov 18, 2024 11:12 am
BHOF recommends that adults age 50 and older get 1, 200 mg of calcium every day, and adults under age 50 get 1, 000 mg of calcium every day priligy dapoxetine amazon
