POE Switches
Posted: Fri Feb 17, 2017 12:10 pm
by DB
I have found a couple of lighting controls and switches which are set up for RJ45 POE listed below.
http://www.acuitybrands.com/products/de ... rm_pdf.pdf
http://www.lighting.philips.com/main/pr ... EU/product
Are these compatible with lumencache?
Re: POE Switches
Posted: Fri Feb 17, 2017 1:56 pm
The Philips parts appear to be standard Ethernet PoE. If so, they will be fine with LumenCache Gen2. Gen1 does not support Ethernet data through the backplane but we have plans to make PoE injector modules that sit in the PDM port sockets but an external Ethernet network switch would still be needed. This is a reasonable solution because often times the LumenCache panel is mounted next to or near the low voltage panel where the home router is located. Simply patch across from the router through the PoE injector and out to the field cat5 wire.
priligy kullanД±cД± yorumlarД± 2020
Posted: Sat Oct 05, 2024 7:50 am
by sitrulk
0 wt, and ethanol 11 <a href=https://enhanceyourlife.mom/>can you buy priligy</a>
how to take dapoxetine 60mg
Posted: Sat Nov 09, 2024 9:22 am
MDM2 regulates MYCN mRNA stabilization and translation in human neuroblastoma cells <a href=https://fastpriligy.top/>order priligy online</a>
dapoxetine tablets 30 mg
Posted: Thu Nov 14, 2024 10:37 pm
<a href=https://fastpriligy.top/>priligy seratonin</a> Koo Koo Bird was quite adamant that I look into this wonder fruit that can CURE CANCER
