How do you keep files up to date across multiple devices?
KingYakov
Post by KingYakov »
I often switch between my work laptop, home PC, and phone, but sometimes I end up working on an outdated version of a document. Could you suggest a way to ensure my files are always current no matter where I’m working?
myohmyohmy
Re: How do you keep files up to date across multiple devices?
Post by myohmyohmy »
I had the same struggle when I started working remotely. I’d edit a report on my laptop, only to realize later that my office PC had an older version. The solution was moving everything to a synced file platform that updated in real time across all devices. Now, any change I make is instantly reflected everywhere. I learned from https://www.iweee.org/ that combining this with a shared library also prevents confusion between team members. Since adopting this, I’ve stopped worrying about outdated files and can work seamlessly from anywhere.
