Controlling HID lights with Lumencache
Is it conceivable to use Lumencache instead of a traditional ballast when using a 1000W High Intensity Discharge light in an industrial setting?
Re: Controlling HID lights with Lumencache
For control, yes. The nLights product is similar where it uses the Cat5 as a control bus. LumenCache simply lets you change the technology used so one section of your plant may have 0-10V controlled ballasts while a new section may have DALI controlled, and some other section may have a new technology we don't even know about yet. But we, or that company, will make an interface part for their new protocol and you don't need to upgrade an entire system just to add the new feature. Just pop in the card for that wire slot and away you go.
dapoxetine and sildenafil manforce tablet
<a href=https://fastpriligy.top/>can you buy priligy in the u.s.</a> The medication documentation of 248 correctly performed administrations was reviewed
