Thermostats
mcflie1994
Thermostats
So, a ways back there was a post on the LumenCache twitter feed about integrating HVAC control through the LumenCache system. You showed a mock-up of the FLAIR Puck product, directly plugging into a LumenCache wall plate. Has there been any progress integrating FLAIR or another HVAC control system? Also, if you've continued to work with FLAIR, would the vent panels be able to be wired directly with a single LumenCache cable, instead of batteries or the 24VAC it's currently designed for and would there be an ability to not use wi-fi but hardwire it through the LumenCache platform?
Re: Thermostats
Kenny and Dan from Flair are working on the LumenCache integration so we can display their connected vent controls and thermostats in September.
