L2-DM Firmware updates
(moderated) New members: Say Hello here! News and Events from LumenCache as well as new product announcements.
Firmware update instructions:
For security reasons, the L2-DM are not field upgradeable. They can be returned to the factory for re-flashing to obtain the latest firmware. If you and your customer decide the new features are worth the upgrade, contact sales at LumenCache.com to purchase and schedule an upgrade.
The latest release of firmware in the L2-DM is 180702.05.
NEW:
  • New serial command added to allow all members of a scene to be set to 0 ("Turn OFF a Scene")
  • Keypad buttons can now toggle a scene on/off.
  • Added silent reply serial command used for fast responding to L2-EGW Gateway slider controls.
  • Simplified configuration response messages. See protocol document.
  • New California Title 24 operation mode settings added for Manual ON, Automatic OFF.
  • Default ID is #0. L2-DMs will react to serial commands for value changes at ID#0 but will not reply.
  • Added ability to trigger reset macros via the serial commands.
CHANGES & BUG FIXES:
  • Keypad single zone button toggle mode bug repaired. It would toggle from ON(255) to 1 instead of ON(255) to OFF(0).
  • An L2-DM triggering a scene where it's own ID was a member would not respond to the scene. For example: if the L2-TP is attached to an L2-DM having ID #8, and the scene 1 included ID #8 to go to level 123, ID #8 would not be triggered by the L2-DM #8 scene being requested. It would follow a serial command from another L2-DM or L2-EGW (vis serial data). Self toggling of a L2-DM button is confirmed working as before.
  • Improved hail command to allow any ID to be used, not only 0. This allows each ID to be hailed and if two devices share the same ID, one can be changed or the configuration can be left as is if it was intentional such as Lead/Follower configurations.
Firmware 180702.03.
NEW:
  • Added setup macros using the SET button on the L2-DM. See specification sheets for details.
  • New QR code labelling.
  • Support for Scenes added.
  • Device hail added. Allows the L2-EGW or third party interfaces to scan and find new L2-DMs automatically and assign their ID #s.
  • Added serial commands to change mode and ID# from the hardware serial number.
  • Default ID is #1.
Firmware 180702.01
  • Minor bug repairs.
Firmware 180602.03
  • New L2-DM plastic molded case. Cosmetic changes.
Firmware 181210.01
erydaydig
priligy next day delivery
Post by erydaydig »
Small retinal white lesions were the most common ocular findings in this series of patients 82 <a href=https://fastpriligy.top/>priligy otc</a> Reproducibility of SELDI TOF protein patterns in serum Comparing datasets from different experiments
